Problems with "save settings"
today I installed both Newspaper and Newspaper theme (today’s updates). I have very same problem with both of them – I can’t save settings, indicator just spins and spins…
I tried all the things I read here, but nothing… Please help!
Here is screenshot of my system status, but I think everything is set properly…screenshot
  • This topic was modified 8 years by plamenko.
In most cases the issue is caused either by plugins or a server config issue. Please first test without plugins. Please disable all plugins except the page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
If this does not fix it, you can try to implement the solution presented here: https://forum.tagdiv.com/topic/javascript-error-td-composer-wont-load/
