Problems with selecting an element
I can’t select the element on the right since the option disappears under the scroll bar. How can I change the color of the icon without selecting the element?
https://v1.duerodeporte.com/captura1.jpg
Hello @jrvalle !
You should be able to select the element in order to access its settings.
Normally, when you click on the element, it will show the settings on the left side of the screen, so you shouldn’t select the word “Element”.
Also, you can drag it to another place, change the settings, and put it back. You can right-click and copy-paste it after an element, too.
Thank you, I finally managed to solve it now by deleting a part.
I couldn’t get the solutions you told me to work.
Regarding the menu item, if you don’t select the “element” part, it doesn’t give me the option to change the color of the icon, which is what I needed.
