Problems with Shortcodes
Steps to reproduce.
Create a Shortcode in TagDiv Composer:
– Right Click on a Row or Element, Save Element
– Add a name
– It creates a Shortcode in the left column.
– Then I can drag and drop from the left rail into the TagDiv Composer
For some reason the ShortCodes are not being saved and I can not delete the ones I already created. Please help.
I just tested this, and it is working correctly. Can you provide some screenshots or a video of the problem?
https://i.imgur.com/tl5CaJt.png https://i.imgur.com/lEhNhZt.png https://i.imgur.com/ydhsUku.png
