Hi, i bought this theme because of the new option to change the global site width.
I want to use 1400px
If i use row strech 1400px and afterwards add in example an Big grid 4, what are the correct options to get it displayed correct at all devices.
Since at smartphone the Big grid 4 element is shown with a left margin and does not use 100% width.
2nd question here – i also show the latest articles (Template Pagebuilder + latest articles + pagination)
What do i have to do here to display everything in 1400px width.
Im open to use my custom css, but i hope you offer setting options to get done via the theme settings.
sorry i meant right margin –> https://prnt.sc/l5lucm
Hi Everybody,
I also have a problem with the grid in 1400px, I was using a BigGrid3 and when i switch to 1400px it was unformatted, then i tried many other untill i found flex grid :=)
then I had to change the margin because my client absolutly want them 20px and the grid is not matching anymore.
i tried with css but I found no way to adjust it.
advise?
thanks a lot
Valerio
PS: http://fabridea-test.de.fc-host61.de/entrepreneurs-club —Grid on top :=)
valerioagolino.
Hi @valerioagolino,
If you are using more then 1200px please use flex blocks or full flex blocks, these should adapt to your size.
Hi Calin,
sorry but i need a grid not a block.
we bought the tempalte becuase of the grid on top, which is what the customer want to have.
I already use the flex grid, but there is a problem the grid is not alligned
… if i give 20px gap it come this error:
thanks
Val.
Hi Calin,
the screenshoot i posted is from a flex grid.
and as you can see the first box have 20px (the gap i used) on the bottom side.
this make the mistake and let the grid not alligned on the bottom.
thanks
Val.
If you want to set a padding or a margin to all flex grid you need to set it in css -> https://www.screencast.com/t/gxSwNvdZ if you set in layout will be apply only on that module also make sure that the settings in layout are set to fit the modules height -> https://www.screencast.com/t/IhKs2JLTkQG
