hello, I am using the social counter plugins, I have set up my channels, clicking on the buttons the links work, the only problem is that they mark 0 in the numbers of LIKE and Followers on instagram. While twitter followers are displayed correctly. If, on the other hand, I try to manually indicate the number of followers they appear. Is it my problem or does the social counter plugin only work by setting followers manually?
my website is http://www.oranotizie.com and in home page you can see thw plugin
This issue has been already discussed here: https://forum.tagdiv.com/topic/social-counter-shows-wrong-numbers/
Hope that helps you!
