Hi, I’m having a lot of trouble using the new TagDiv Composer. I find it very difficult and frustrating to use and I can’t easily get the results I’m after. Sorry guys!
I would like to go back to using the original composer. How can I do this without there being any conflicts between the two composers?
Hello LMPLMM,
Please make sure that you are using the latest version of the theme installed via FTP way because this is the surest method in this case. If the problem is still there, try to make a new clean install to another sub-domain via FTP way, clear all the caches and check the results. If the error persists, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page.
