Problems with tagdiv Composer.
After last update, tagdiv Composer don’t work.
I don’t see TagDiv Composer Button on backend editor. If i try to modify the pages created with it, the system show me bar alert like “This current content hasn’t a page created bu tagDiv Composer”
Hello fakiro,
Notice that we do not recommend to use both page builders in simultaneously mode, sorry! You should remove the Visual Composer if it is enabled. Also, try to re-create the page using the TD COmposer and check the results.
