Problems with tagDiv Composer
// EDITED //
When I want to edit the site with the TD COMPOSER, the site can be load and freezing.
  • This topic was modified 7 years by Vlad S.
Hello !
Your homepage seems to be working fine. Also please note that if you want to edit single post templates you will have to add them from Cloud Library.
All the Cloud library elements are fully editable using the tagDiv Composer.
Find out more about it here: https://forum.tagdiv.com/cloud-library-templates/
