Trying to use FlexBlock 1 on our site. Pulled in a sample template to get the look we wanted. Also tees to add the same look on my own. Neither are working. Can not edit the # of posts per column. Can’t edit the photo placement. And can’t edit the fonts. When I make a change in the settings nothing happens. Once I hit save it reverts back to the original. Any ideas. I’ve spent a few hours trying to figure this out with no success.
This is due to caching plugin. I have been suffering the same for long.
Please make sure you don’t have an object cache.
Also, please check the console when you try to save the changes made with tagDiv Composer maybe is possible to be from the firewall or securitymodule which blocks the admin-ajax.php request, which usually displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module that blocks this.
If you use a plugin like Wordfence please set it in learning mode.
@anamaria . I fixed this issue.
Cause: Caching plugin rendering not updated content which conflicts with the tdcomposer.
Fix: Either clear cache or open an incongnito mode and login in admin panel. When opened, it reflects live updates without error.
I do not have a caching plug in installed. Tried clearing cache under “Quick clear all cache” Still nothing.
This reply was modified 3 years by
mcneillmedia.
Went into a private browser window and everything worked. So how do I fix this so I can use a regular browser window and not go incognito? This is a test site which is fairly new. I have not added any extra plugins yet. Do we need to ADD a cache plug in? Not sure what is causing the issue.
