Problems with tagDiv Composer and tagDiv Multi-Purpose
I have a new installation with the latest versions, using the DENTAL STUDIO theme.
Editing with TD Composer some features to change the colors is not available.
Please see the images:
capture 1
capture 2
Hello tec99,
There was added a gradient and that’s why this rule was hardcoded. If you want to use another color for this section you should choose what color you want from the Composer and then add the following code to Theme panel.
The code is here ->
.td-dentist .tdm_block_testimonial .tds-testimonial3 .tdm-testimonial-descr {
background:transparent;
We will fix in the near future update, sorry!
