Hello, I have problems with “here” because when sharing on social networks, when users enter the URLs that end in “here” only the first part appears and the rest of the content is blocked, that is, it does not scroll, any solution?
My website https://modooculto.com/
Url example https://modooculto.com/significado-de-sonar-que-nos-roban/?tdb_action=tdb_ajax
Hi duvanuk,
From what I can see the infinite loading is not working at all on you website, please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
let me know the results!
That is related to the infinite loading functionality. But how would users reach those URLs without adding the parameters in the link? I browsed the website, seems fine. Are there any actual errors created by this? the ?tdb_action=tdb_ajax can be found in wp-content/plugins/td-cloud-library/includes/tdb_ajax.php
-> https://www.screencast.com/t/7400Q1uytj and you can add a rel=nofollow tag when this link
All url ending in “?Tdb_action=tdb_ajax” only shows the header and does not allow scrolling.
Example: https://modooculto.com/significado-de-sonar-que-nos-roban/?tdb_action=tdb_ajax
Example 2: https://modooculto.com/significado-de-sonar-con-dios/?tdb_action=tdb_ajax
Example 3: https://modooculto.com/significado-de-sonar-con-pulgas/?tdb_action=tdb_ajax
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
