Problems with the location of the blocks
Hello from Buenos Aires, Argentina
http://www.laribera.com.ar
I have problem with some blocks,
the blocks moved,
look at the attached image
http://i66.tinypic.com/2z8yovb.jpg
Hi JorgeA,
First of all, please make a full back-up to your database, update the theme to the latest version of it which is Newsmag 4.5, remove all of the untested plugins, clear all the caches, purge CDN files and check the results.
