Hello, I have installed Newspaper in http://www.lavozdelviso.com and, since last week, when I entered the web on any device, it always load the mobile version instead of the desktop, what can it be?
I have inspected your site but I do not see any problems at the moment – https://www.screencast.com/t/ANVvK9db If Please make sure that you have updated the plugins that are provided wit the theme, in the theme package, to the latest version. If the problem occurs again, try to disable all the plugins except Visual composer and the mobile theme, clear the cache, verify any code entered in the theme panel or added to the theme files, then check to see if the problem remains.
