Problems with theme Newspaper and bbPress forum
Hello all!
I bought Newspaper theme and instaled bbPress pluging forum and i stonned when i wanted to start working on it but have no options of work or edit the forum on my wordpress display menu.
Any ideas? Do I miss something?
Hello Ayudaenibiza,
Please ensure that you have the plugin installed correctly and that you have it enabled. I’ve tested on my side and everything seems to work properly. http://screencast.com/t/E59yia1ho4GX – http://screencast.com/t/tqLbaQaM
Hi Catalin,
Thank you for your answer, i´ve already checked it but still the same.
Actualy, i´ve the plugin instaled but the problem is that I can´t manage it because it doesn´t show up in my WordPress menu.
Before Newspapter i was working with Nexus from elegant themes and forum was working on it, but now with my new theme Newspaper… it doesn´t
What do you think?
Hello Ayudaenibiza,
Please try to disable all the active plugins, except Visual Composer, clear all cache and install only the plugins that come bundled with our theme and try again. It may be a conflicting plugin. If your problem is still there, after these changes, please send us an email at contact@tagdiv.com and provide your log-in information so we can take a look at your page setup. Please also provide a link to this topic so we know who you are.
Thank you for the message!
Hi Catalin,
Everything fixed atm, it was a Pluging conflict.
Ty very much 😉
