Problems with VC upate
Just tried to update Visual Composer on Agenturer.no. I followed the steps you describe.
However when I tried to reinstall the plugin (after deleting it) from your plugin page I only get a message that “we are sorry but you don’t have access to this page”.
As I need the page to be up and running I went ahead a purchased a license for Visual composer and installed it seperately instead. However – I would prefer to use the license that goes with Newspaper.
What is wrong here?
Best wishes
Lars
Hi Larshell,
I have inspected your website and I saw that you managed to install the latest version of Visual Composer, right? If you will encounter another problem with the theme, please open a new thread with your issue and we will gladly help you.
Yes. But as I wrote above I needed to buy it separately. I didn’t work through Newspaper.
Hello Larshell,
Unfortunately, you must not buy the License of Visual Composer, sorry! The license comes bundled with the packet which you have downloaded from Envato Market and until now we have not encountered any problem in this regard, sorry!
