Problems with video embed within accordion
Hi, I need to insert videos within an accordion structure. When I do this using either the video shortcode or the vimeo embed code, it looks fine within the setup page but when published it gets shrunk down to a thin line.
see here: http://wellnessatwork.com.au/wp-content/uploads/2017/06/Video-embed-screenshot-200617.png
I’m assuming that the css is overriding it but am unsure how to fix it. Can you please help? I need to publish this tomorrow.
The Accordion element may not be suited for what you are trying to achieve. The same thing happens for me as well
– https://www.screencast.com/t/zIuMRidtN
Also the Tabs element is known to cause issues with videos. You could try this code and see if this fixes the issue, just enter it in Theme Panel->Custom Css. Clear any caching installed after you enter the code.
.vc_tta-accordion iframe {
height: 100%!important;
