I´m having some problems.
1. Revolution slider. When I try to add a new slider I have this: ‘Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 83 bytes) in /var/www/vhost/segoviaudaz.es/home/html/wp-includes/category.php on line 343’. And the same when I go to settings.
2. Visual Composer. It doesn´t let me to add any element.
Thank you
Please make sure you increase your system status parameters like this guide shows: https://forum.tagdiv.com/system-status-parameters-guide/
Also please disable all plugins except visual composer, clear cache and reset cdn files.
Let us know how it goes.
Thank you! Visual composer is now working but Revolution slider still doesn´t
Good morning, can someone please tell me how to change the category names on the home page? The blocks with all the posts below?
I’ve looked in categories, in the Theme Panel, but there is nowhere to edit or delete those which are shown on the home page.
Any urgent help is much appreciated!
Everton
Please open a new topic if you do not have a related issue.
The homepage blocks can be changed on the page edit screen in visual composer. Please read this guide to see how you can filter the categories in the block settings: https://forum.tagdiv.com/block-settings-guide/
