I’m using W3 Total Cache plugin as per your recommendations. I’m only using page cache, but i still have issues with cache on the site.
For example, when i do logout through login-form plugin (placed in top header), i still see my self logged in, and if i publish a new posts it won’t show on the BigSlide.
All problems disappear when i disable W3 Total CAche plugin.
There are many other parameters on the plugin, i’m not sure that everything is as it should be. I’m sending my W3 Total Cache configuration to you by mail.
Thanks for your help
problem fixed through mail by Emil:
You changed the w3 total cache settings, and also used other options like disk cache – http://screencast.com/t/6s4PbRAsle8H
Thank You
