Problems with WooCommerce Waitlist
I have to commend you first, the shop extension is great. However, there are a few small problems, especially with the WooCommerce waitlist.
The plugin doesn’t work if you use the composer for a product page. This is impractical, because we are dependent on the plugin. Although it works in the standard templates, a single product then looks anything but good.
Do you have any tips on how I can get the waiting list integrated if I want to use the Composer?
Oops okay, shortcode found, but a question remains. If a product is not available, the “add to card” button should disappear, which only confuses customers. Is there a corresponding possibility?
  • This topic was modified 5 years by Micha.
If the product is not available a message appears when you want to add the product as it is not available => https://www.screencast.com/t/lCqmfMJYn but I will send this suggestion to our developers.
Thank you so much for your feedback and kind words!
Have a nice day!
Sorry for the very late reply.
Your idea to mark an item as unavailable is quite nice, but absolutely impractical for a store. The customer must know in advance that he can not buy a product, so you only annoy customers. At least the “Add to Cart” button needs to be replaced with a notice that it is currently unavailable.
Also, you should not exclude plugins like the “woo waiting list”, because this way you lose potential customers.
Overall, your plugin is really great, but not thought far enough, it lacks important elements that are very important for a store.
This plugin is still in its beginning, but in the future, we will add new implementations, we add new options depending on how they are requested https://i.imgur.com/MAFaiGF.png -> https://tagdiv.com/newspaper/
I hope that this option will be implemented in future updates.
yep i know you guys are working hard to improve the theme. One of the reasons I use it on so many client projects now.
It would be great if you include the notes for WooCommerce in your ideas list, because in my eyes they are important so that you can use the theme reasonably for stores as well. You can add it manually in the code, but that’s with tens of customers, after each update quite a lot of work.
Yes, I have added these requests to our list.
