I have recently updated the Newspaper theme with the latest version 9. The previous version of the website was built with WPBakery and after trying to use the new TagDiv Composer i haven’t been able to make it work properly (slow, cannot delete rows etc.) I read the instructions on how to setup PHP.ini and Htacess (default values) and still it doesn’t work. After disabling TagDiv Composer i was able to get the homepage running like it used to be and decided not to use TagDiv Composer for now.
Could you help me with activating TagDiv Composer?
Secondly, I’m not able to visually edit tables like i used to before the update. What seems to be the problem? If you need the credentials to access the website and cpanel please let me know how could i send you this information.
Many Thanks,
Dejan
Plea note that you can not use the both builders on the same page, if your website was build with WPBakery, that pages can be edit only with WPBakery not with tagDiv Composer
Please check our documentation -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
tagDiv Composer tutorial -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
How to use Visual Composer -> https://forum.tagdiv.com/how-to-use-visual-composer/
If there are still some problem please provide some more details and some screenshots, that would be very helpful.
