Problems with Yoast SEO after Newspaper Update (not resolved)
I received a message that the truth is surreal, as they have not solved the problem.
“Hi,
As far as I know currently there is an issue as you mention. While in the classic editor the Yoast content analysis should work fine, in Gutenberg there are a few problems. For example the links detection may not work correctly when using Gutenberg. This is already on our list and our developears will try and fix it as soon as possible. Sorry for the inconvenience. “
Specifically, when will the problem be solved? Because it is a complex issue, considering that you incorporated changes that are appreciated, but have resulted in several failures for the community. Therefore, it is necessary that you can resolve the error that you yourselves created as soon as possible.
Thank you in advance for your response.
Best regards.
We are aware of the issues, and our developers are checking this problem, when this will be solved, the will be make an update to the theme, we hope this will be soon.
Is it important to mention that the problem with Yoast is not just in Gutenberg.
I have I the classic editor and I have the same problems.
Gutenberg itself mentions that Gutenberg is a beta version and shouldn’t be used for official productions, which I why I only use the classic editor.
