Try to disable all plugins, enable only Visual Composer and Speed Booster, see if the issue is still there. Also make sure you use the Speed Booster version that came with your current version of the theme.
ex . If you have the latest version of the theme (4.6.1) you should have Speed Booster version 3.1
Thank you, Emil G.
you’re right , there are plugins that was blocking me the web
Emil G, what if you need the plugin that is conflicting with the speedboost? Also we notice after activating the speedboost plugin, the post counter and ajax next post option stops functioning. There is another person reporting the same issue. After you disable the speedboost, post count works and all ajax functions basically work again. Any thoughts?
You could try an alternative to that plugin if you need it or address the matter to plugin author also maybe they can help you make it work together with the theme.
The post counter and the ajax next/prev post pagination work based on js so I suggest you check your console for js errors and also check this without any plugins active just the VC and speed booster plugin as the speed booster plugin moves scripts and style sheets to the bottom of the page and this could cause conflicts when used with other plugins.
Please make sure you try this and let me know how it goes and also provide your site’s URL.
