Product Description Issue
If you add content in the main content editor for a WooCommerce product, the resulting page shows the content in the Description box that theme provides, but the word ‘Description’ appears as a header in the content box. It’s redundant.
How do I remove this?
If you mean this heading – https://www.screencast.com/t/Sk7fefcZJ
I believe that is added by Woocommerce here – https://www.screencast.com/t/fLAmDLaaGHY
You could edit the plugin and remove it in the files as shown. Or remove the heading with some CSS like this
– https://www.screencast.com/t/FV6xAUqEMRVk
.single-product .woocommerce-Tabs-panel h2 {
display: none;
Maybe add some margin as well to compensate for the removal of the heading, if you want to
– https://www.screencast.com/t/A9i5TB8GTZ
.single-product .product ul.tabs {
margin-bottom: 30px!important;
Very nice. Thank you!
