Product page for simple product returns an error
I am working on a site with woocommerce and the product page does not work for a simple product.
Steps that reproduce the issue on the site:
– create product as simple product
– the product gets listed in the catalog
– the product page returns an error: “There has been a critical error on this website.”
– after changing the product to a variable product, the product page works fine.
When changing to one of the free templates the product page work for both types of products, simple and variable products.
Geert.
I did a test and for me works -> https://i.imgur.com/a5CdeRC.png -> https://i.imgur.com/244L4GU.png
Thank you for your quick reply. I can understand the assumption that it should work as your test shows the correct result. But when I do some further tests, I find that when using TD composer adding the WooCommerce shortcode Woo Add to Cart makes the page fail. In fact, I removed everything from the page and obviously it shows a blank page with the header and footer, and more importantly no error. When I add the cart shortcode, the page fails.
Any suggestion on what I can do to troubleshoot?
Please make sure that you have the tagdiv Shop plugin installed and activated.
