Products element not displaying new viewport elements: woocommerce
I have noticed a problem with the theme.
I have configured the Woocommerce product page on Cloud Template.
I select the Shop page on Cloud Template.
From the Shop page, I open the Woo product templates page.
I configure the product by adding social sharing, favourite product, and TAG.
I save the page.
These configurations are not visible in the product.
Can you check why this is happening?
Document screenshot https://drive.google.com/file/d/1Sbvt3s-LzCM_-JEwFNuxwOJTPd3k8otd/view?usp=sharing
Site: http://www.acquadellemarmore.it
Site access
User: NewspaperT25
Password: sent to your e-mail address contact@tagdiv.com
If I’m right you are using the default template and not the cloud one – please select the cloud one as global – https://i.imgur.com/KjDiH3f.png should be green like this one – https://i.imgur.com/IZHBiDo.png
Grazie.
Problema risolto.
