This is the site,
there are some modules that are not loading any post, I already try to change settings, categories, etc. and nothing
You need to check the filer on the block in the tab filer.
Please check if you have an offset on the block. . Please edit with tagDiv Composer -> https://i.imgur.com/j8YvKks.png. Click on the block and remove the offset -> https://i.imgur.com/dJ0iFQu.png. Let that field empty.
