Hello guys,
I’ve just installed Newspaper and the Pulses PRO demo along with it. I noticed that the single post template is misplacing the author and read more boxes as you can see here, making them overlap with the post content. However, when I press the Edit template button on top, the boxes are rendered correctly.
The only plugins I have active are those installed with Newspaper, plus Akismet and Jetpack. I’ve also made no changes to the overall configuration via the template panel. At this point the installation is pretty much on vanilla state.
I wonder if you have any thoughts?
I think that this is a plugin conflict between tagDiv Cloud Library and WPBakery, you can use only one of them, you should decide which one you want to use, we recommend to use the tagDiv Cloud Library with tagDiv Composer these are the theme plugins.
Please deactivate the WPBakery and check the results!
Let me know the results!
