Questions about conversion of existing multisite
Hullo Team TagDiv,
I’m a worried man 🙁 I have a site broken into four major and a few minor sub.sites. In total there are way over 35k images and 2k pages/posts.
I’ve spent the past couple of days falling in love with your theme but am really concerned about what will happen if/when I apply it to my site. Even updating/editing 20 posts a day will require 100 days of work. I realise the easy solution is to duplicate to a test site but the live site is 34gb and growing daily. Duplication isn’t an easy task.
I’ve reviewed all your videos and read all the documentation but my concerns remain simply because your theme is so radically different to the one I am using.
My site is http://theownerbuildernetwork.co
Any thoughts, suggestions or insights?
Thanks DW
You may not need to update the posts, if you use default wp post types: https://codex.wordpress.org/Post_Types with a featured image set for posts. To test that you could try to setup a new test wp install and recreate your current environment with a few posts and pages and then apply the theme and check the result.
Hope this helps! Let us know how it goes!
