Hi Newspaper-Team,
I have bought the great theme newspaper 8 and setup a test website with the demo „beauty blog“.
Now I have some questions:
1. How can I enable the shadow of the header?
2. How can I edit the content of the „post-site“. The menu item „edit with TD composer“ is only shown, when I am on the startpage. So I can’t change the content of the „post-site“ with the TD composer!?
3. I want to show in the „post-site“ the same sidebar as it is shown on the startpage
4. I want to change the link-style in the post text. Where can I change it, that the link has a background color and another hover color?
Thank you for your support!!
1. Each demo has it’s own custom implementation. The beauty blog has the shadow removed as a design choice. Which header style do you use?
2. I;m not sure what a post site it. Sorry. Only static pages can be changed with the page builder. Posts are edited in the back-end using the tiny mce editor. Other template such as the blog roll template are handled from the theme panel-> template settings
3. The sidebar on a post is different than the one on the page. The one on the page is not a standard sidebar but rather a a sidebar created for that page specifically directly in the page builder on a split row. It will have to be recreated in the widgets section if you want to have the same design.
4. The links grab the color from the theme accent color. There is no setting to change the links separately. https://www.screencast.com/t/V72pxWbMH
