Questions and issues regarding the "Block 1"
Hello there,
I have a few questions related to the “block 1” of the newspaper theme.
1. Is it possible to list by default all latest articles? I set the options for that block to “latest” – that should be enough, right?
2. Further, is it possible to order the categories in a specific way? F.e I want to put “Champion League” right behind “Alle News” – is there a chance to do that?
1
3. What are the factors for the amount of categories getting listed in the section and not under “more”? Is it simply the wordlength of the category itself?
  • This topic was modified 8 years by Skryzer.
1. Indeed, the latest post sorting will display posts as soon as they are published, from the categories you choose. That is for all block and grid types available.
2. Those can be arranged as you like. Enter the category IDs in the order you want, in the ajax filter field
– https://www.screencast.com/t/nSL9TrsFH
Category IDs can be seen here for example
– https://www.screencast.com/t/6EI6zvxKznfr
With the ajax filter you can have only specific categories displayed.
3. The “More” dropdown will appear when there is not enough space available to display all the categories.
Please let us know if you have further questions, or you need help with something.
Hello Simion,
thanks for answering and explaining! It worked like a charm. Thank you very much! 🙂
