is it possible to insert an ad in a flex block?
I am using flex block 4 on my front page and posts loop for kategories. In posts loop I can insert ads after every x posts. I need to insert ads into my flex block 4. How can I do that?
Unfortunately the handling of ads is different in the different widgets and sometime even within one widget.
In ad box I can define where an ad is shown (all devices, tablet, mobile…), but only if I add it as image ad. How can I remove a custom ad on a mobile?
In posts loop there is no such thing as an image ad. How can I remove it there?
And to get back to my first question: If I can show an ad in a flex block, how can I do that only on a desktop?
Kindest regards,
Brigitta
Unfortunately, for the moment there is no option to display ads inside the flex blocks , the only ad that can be set in the flex block is for the video popup -> https://i.imgur.com/5BmAQwe.png
About the ad box, indeed this has special options if you are using banners/images, but for AdSense code you need to use a specific code or using the settings from ads, for example -> https://wpadvancedads.com/disable-adsense-on-mobile-devices/
