Questions Regarding Fonts, Featured Images, And Social Buttons
Hi there guys,
I’ve recently bought your newspaper theme. My site is http://www.ClearAwayAcne.com
I have a few very important things to get settled regarding my theme customization.
1. I want to change my theme typography to which you use in your fashion template, and I want to make the title a bit more prominent by either underling it or increasing it’s size. I also want to ask that can I choose a separate colors for H1, H2, or H3 titles?
2. How can I disable featured posts from appearing in posts? It’s causing a single picture to appear two times.
3. I don’t want the pinterest buttion on the social sharing buttions after every post, and can I include any CTA with these buttons? Is it possible?
4. How can I avoid the same posts displayed on my home page multiple times?
It’s a big list though, but I desperately need to do these tasks,
Hope you’ll help ASAP 🙂
Sheikh.
1. You can import this predefined syles like this:
http://screencast.com/t/yLOZrUAt
http://screencast.com/t/qLSTINIg
Do you use the default template? – http://screencast.com/t/e4Itye2zr
You can target h1, h2, h3 with custom css (add the css inside the Theme Panel -> Custom CSS):
h1 {
color: red;
h2 {
color: red;
h3 {
color: red;
But this will affect all h1, h2, h3 titles on the site, you have to add a specific class to target them only on the pages/posts you want.
2. I belive you are reffering to the featured image. The feature image can be removed like this: https://forum.tagdiv.com/how-to-hide-the-featured-image-on-post/
3. You can delete the code (or modify it) from the td_module_blog.php – http://screencast.com/t/ZiGcAU70s
You can find code for the other buttons above it, modify them to behave the way you want.
4. If you don’t use pagination or load more / infinite load options edit your home page and enable the “Unique articles” option like this: http://screencast.com/t/pUaAtaYg
If you use pagination configure blocks to display different categories.
Thank you, Emil G.
I’m using the default template.
Pasting this custom CSS in the panel doesn’t work at all.
I do not have ANY idea how you’re talking about modifying this code (regarding sharing buttons). I couldn’t find that class in the theme editor from wp appearance panel.
Please let me know from where I can access the theme code like image you provided. And also, tell me how I can add a few words to this sharing box if I wish.
1. Replied via dashboard, you have to specify exact locations on where to apply the modification.
2. You have to use a code editor like notepad++ and you have to know some basic css/php to do those modifications. If you don’t know how to doit you have to hire a programmer to doit for you, you can always find one on places like http://studio.envato.com/
Thank you, Emil G.
Thanks mate that code worked perfectly fine.
And I just don’t want to get on to that sharing button’s code at the moment.
Just tell me the correct code for modifying H1,H2,H3… tags on my site.
I want to change their color and modify sizes.
You need to inspect elements and target exactly each H that you want to change the color and font size. Use inspector from Firefox or Chrome.
Here is an example: http://screencast.com/t/h04pIe8BM
Thank you
Alright, done! Thanks a lot 🙂
