Forum Fonts
@sixdivision
Not sure how you could do it the theme doesn’t have an option for doing that and WordPress deals with it, you could try to find a solution for it online.
@mrbogdan
If you also need the xml files of the demo you can make a request for it on email and we will send it to you. Send your request at contact@tagdiv.com and also include a link to this topic.
Hi Lucian thanks for the reply, I can change it in:
.header-logo-wrap .td-logo-text {
display: block;
font-family: ‘Life Savers’, sans-serif;
accessed from appearance>>edit in wordpress menu
I’ve misunderstood you, I thought you refer to your site’s title.
Glad you’ve managed to do it.
Who can tell the developers e-mail?
Use the one I’ve given above:
@mrbogdan
I have purchased this theme and installed on http://GizmoBolt.com
I am facing certain issues.
Q1 – How to access the pre-defined Footers, I want to display my wish content their not the posts and categories, How to do it ?
Q2 – While opening category links, menu bar is acting weired, Kindly see screenshot and reply how to resolve this issue.
http://www.gizmobolt.com/wp-content/uploads/2015/02/Screenshot-12791.png</img&gt;
Q3 – I have added custom Ads code in “Home Page” displaying on home page of website, but ads are not coming below the “Big Grid” – they are 728×90 Ads – 2 in number.
http://www.gizmobolt.com/wp-content/uploads/2015/02/error1.png</img&gt;
Q4 – Facebook Counter is always showing 0, Why ?
Q5 – New Posts are not appearing on latest articles, Why ?
1. Please disable predefined content from Theme Panel: http://screencast.com/t/FTK8Alob7S
And add your widgets to the footer: http://screencast.com/t/yDiynisBPJ
2. You can remove Big Grid subcategories if you uncomment this: http://screencast.com/t/ER6dGosc
3. I have checked your site and found that you have an add above Latest Articles: http://screencast.com/t/LIoCziNRyo
4. I tested with your ID and seems to work: http://screencast.com/t/HXpya3Jml – http://screencast.com/t/pK5q3jAeHv
5. Please provide more details. This is your last post? http://screencast.com/t/YgWUkNah
Please post your issues here in newsmag section: https://forum.tagdiv.com/forum/newsmag/
How do I obtain a Visual Composer License so I can update the plug-in?
Thanks,
The Visual Composer plugin that comes with the theme is licensed to the theme, the license specifies that only we can provide the updates and you don’t have to buy it or register it.
We’re testing the plugin latest version, if everything is ok we will include it in the next update and only then you can update the plugin by downloading the theme latest version and following the procedure presented in the plugin update guide.
Till then please ignore the update message!
Can I add some css code to make the wordpress search field stand out against the white bg? I want to add a bigger border.
http://bestseattledayspas.com/
@jtbaker1971
hi – that has nothing to do with “forum fonts” …
please create a *NEW* topic for help with your question, please 🙂
Viewing 11 posts - 26 through 36 (of 36 total)
