Have made a page with random posts. They show up randomly on desktop by not on mobile. https://brandinginasia.com/threeads/
Suggestions?
Hello bobbymc,
Please provide some screens with your Flex Box settings so I can take a deeper look inside it. I have made some tests on my website and the Random Post sort order works as expected, as you can see here -> https://www.screencast.com/t/7EXljMDxZECj
Yah. I’ve done the same setting as you. Just seems to be a problem on Mobile.
Have a look at the home page – see the “Two Ads I like, One I Don’t” block section in the middle of page. That flex is set to random and works fine on desktop but try it on mobile always shows most recent posts.
http://www.brandinginasia.com
I have inspected your website but this section it seems to return the same results for both devices (desktop and mobile). Is it set up the Random posts? Provide the front end settings for this section from TD Composer so I can take a closer look at it.
