saludos tengo problema de alineacion las imagenes se ponen del lado izquierdo
Hi Andrea,
Unfortunately, on our forum, that functionality has been custom made and the theme does not have any such an option that allows you to do this, sorry! You can try using such a plugin with this functionality and check the results. -> https://www.wpexplorer.com/comment-user-badge-plugin/
