When I insert code into a new “Raw html” element through visual composer onto my post it will scramble the code into gibberish as soon as the post saves and the page reloads. When the page reloads the raw html elements are missing and visual composer stops allowing editing of the elements. The subtitle will then be overlay with gibberish. example below.
I am trying to insert amazon associates html code. It usually works but has stopped since the update.
How it looks when setup in VC
http://s21.postimg.org/zc5e87e87/visual_composer_setup.png
How it looks after saving
http://s15.postimg.org/ssnz8n58r/after_save.png
How the subtitle looks after it scrambles
http://s12.postimg.org/xx7tf9ewd/subtitle.png
But the code works
http://s10.postimg.org/4dc9ch3rd/code_works.png
Link to scrambled subtitle
http://theengineeringmindset.com/building-services/
Page with VC
http://theengineeringmindset.com/video-tutorial-how-a-refrigeration-cycle-works/
I’ve checked your site and noticed that you’re using an older version of Visual Composer plugin. I am not sure if this affect the way your affiliate link works but you can try to update the plugin at the current version available with the theme on themeforest, V4.9, clear all caches, deactivate all others plugins, leave just Visual Composer active and test again.
If you still can’t manage to solve this issue please provide the code that you’re using via
http://pastebin.com/ so I can inspect this closer.
