Raw Html Problem
Hi, I tried adding a raw html widget and it gives me gibberish, i read that you need to use the text column. when i try adding any text the editor itself doesnt work, the window opens up but there are no buttons and you cannot save the text. I tried to use multiple browsers. I have newspaper 9
thanks.
There is an issue with some of the text elements and also raw HTML, I believe today the investigation will be concluded and the theme re-uploaded. I will let you know when the issue is fixed so you can re-download the theme package and install it.
We are very sorry for this inconvenience.
You could return to theme 8.8.2 in the meantime, if you do not have that them version we will provide it to you. Send us an email at contact@tagdiv.com and request it, include a link to this topic in the email. Sorry again.
The theme has been re-uploaded, the issues with the text and raw HTML elements have been fixed. Please download again and install it.
There should be no more problems in this matter. Sorry again for the inconvenience.
