re: TD Composer does not load, amoung other things.
I have had newsmag for some time now, even though, I am not a coder, I rarely run into theme issues on modern designed themes, then I installed Newsmag, ROFL.
first thing to note is that I installed the latest Newsmag + TD Composer, on a fresh WP install with no other plugins, so I already know this is not a conflict with other plugins since I had not other plugins installed at the time.
1: TD Composer does not load, or the spinnning circle of death
2: Videos do not load in-content, however, they do show on page
I have also noticed some jquery errors, however, not sure if all this is related.
on page inspection:
jquery.js:5921 Unrecognized Content-Security-Policy directive ‘require-sri-for’.
(anonymous) @ jquery.js:5921
about:blank:1 Unrecognized Content-Security-Policy directive ‘require-sri-for’.
tagdiv_theme.min.js?ver=4.9.5:302 Uncaught ReferenceError: setMenuMinHeight is not defined
at Object._lazy_callback_resize_500 (tagdiv_theme.min.js?ver=4.9.5:302)
at tagdiv_theme.min.js?ver=4.9.5:306
my host was kind enough to send me a screenshot, however, I will have to type it out manually
warning: undefined constant TDC path legacy will throw an error, bla, bla..future version of php /path/public_html/domain/content/plugins/td-composer/td-composer.php on line 114
This may be interesting also:
Fatal error: Uncaught Error: Class
‘td_util’ not found in
/wp-content/themes/Newsmag/functions.php:52
#0 /wp-includes/class-wp-hook.php(287): {closure}(false, Object(WP_Query))
#1 /wp-includes/plugin.php(206): WP_Hook->apply_filters(false, Array)
#2 /wp-includes/class-wp.php(658): apply_filters(‘pre_handle_404’, false, Object(WP_Query))
#3 /wp-includes/class-wp.php(748): WP->handle_404()
#4 /wp-includes/functions.php(1285): WP->main(”)
#5 /wp-blog-header.php(16): wp()
#6 /index.php(17): require(‘/home/digit152/…’)
any ideas from you coding gurus that never sleep?
Thank-You
1. For me if I use only theme plugins -> https://i.imgur.com/pButuq6.png I do not have any problems editing with tagDiv Composer -> https://i.imgur.com/ikZzuB3.png
2. Please provide some more details about this problem, a link and some screenshots
As for the errors, we need to investigate them to see what it can caused those errors and how can be fix.
To investigate and find a fix for the problem 1 and the problem with errors we need to have access to your website, for this, please make a full backup and send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
I posted a topic about this right know, but I can contribute with a fresh relevant excperience here.
It seems to be a problem with the WooCommerce plugin, if you use that. I deactivated WooCommerce, and then the TD Composer worked fine. I think this is something you really need to fix ASAP. Without WooCommerce, I will not have any income… Maybe it’s the same for others, also.
I really can’t confirm that since woocommerce is not installed on the location of the blog, however, I did disable woocommerce on the home site, which I got a fatal error.
It just seems that I run into endless issues, it does not matter if it is newsmag theme that I have installed for the blog or another theme that I use on home directory.
I am almost tempted just to shut it all down, and write it off as it want meant to be.
Every image on my home has vanished (which is not newsmag)
I am starting to wonder if having two wordpress installs one for the shop, and one for the blog is a good idea, or if there is a possible conflict between the two WP installations, these issues just never seem to end, and the #1 reason I use a WP for its own blog is that built-in theme blog templates are so bad…
Hi dsimms, if you have last theme version (4.9.5) and WordPress (5.5.3) and you tested only with theme plugins and the problem persists, please make a full backup and send us and email to see what can be the problem, this is the only way that we can inspect the problem and help.
I have resolved the issue with the TD Composer. The issue was found in htaccess in the root directory which prevented the editor from loading in two different themes that were located on sub-domains.
I still have the following error when I inspect the home page, maybe this is an issue, or maybe it is an error that can be ignored, please let me know either way.
footer-cc6e741d530757840e3205acc9614d07a0036141.min.js:304 Uncaught ReferenceError: setMenuMinHeight is not defined
at Object._lazy_callback_resize_500 (footer-cc6e741d530757840e3205acc9614d07a0036141.min.js:304)
at footer-cc6e741d530757840e3205acc9614d07a0036141.min.js:308
_lazy_callback_resize_500 @ footer-cc6e741d530757840e3205acc9614d07a0036141.min.js:304
(anonymous) @ footer-cc6e741d530757840e3205acc9614d07a0036141.min.js:308
  • This reply was modified 6 years by dsimms.
Normal those errors should not affect the theme, normal the above code is referring to theme footer, but as long that the footer zone is working, there should be no problems.
If there are still some problems, let us know!
