Read more background color, text color and color while hover
I need changes of read more button color on my homepage. Here is what I got now.
My current CSS Code:
https://www.screencast.com/t/I3Uy1W86a
My current result:
https://www.screencast.com/t/lQlctVvvV9xW
My expected result:
https://www.screencast.com/t/TmIEpd29zCo8
My sites: toeflbb.com
Also, Is there any elements list of buttons in CSS
appreciate your help 🙂
  • This topic was modified 9 years by dukai1011. Reason: update
The code is correct but it does not have priority, since the code from the theme has an !important tag
– https://www.screencast.com/t/NhV6veBKh
You must use this tag also in your code so it forcibly applies, like this
– https://www.screencast.com/t/EqnNR1et
Now there should be no problem for the code to work as intended for you.
solved
