Hi, i was reading up on the read more feature as i could not get it to work on my newsmag website and came across a forum post by someone from TagDiv on the envato forum saying that the theme doesn’t take it into account in and of itself but there are workarounds to get it to work, attached to the post was a link supposedly leading to such workaround but it doesn’t work anymore. This said i would like to know just what i need to do to get my website to work with the read more tag on all modules
Hello twindrills0401,
Unfortunately, our theme does not have any such an option that allows you to use the Read More button for post pages, sorry! As you can see, our theme has this option implemented in some modules/blocks which use this structure. For more references about this case, you can follow the following topic here -> https://forum.tagdiv.com/topic/read-more-button-and-cant-change-title-color/
If you want to have this option on your website, you should use such a plugin with this functionality and check how it will work for you.
