Read More on Blocks
Hi!
I have activated block 4 on my page and I wuold like to add a button “Read More” in every box on the block.
What is the way to do that?
Thanks =)
To achieve that you need to edit the td_module_2.php file and add this code like here: http://screencast.com/t/Gkgh5nzx3 – http://screencast.com/t/M8EOdj5Awtvw
<div class="td-read-more">
   <a href="<?php echo $this->href;?>"><?php echo __td('Read more', TD_THEME_NAME);?></a>
</div>
Note that the Read More button will appear each time when module 2 it’s used on page.
  • This reply was modified 10 years by Andrei L..
Cool! It works Andrei!
Thanks a lot!
