Real Estate Pro Currency symbol ($) remains same when changed.
I’m still building the site https://propertynia.com. However, when I change the default currency ($) through the properties field on ACF plugin page on my dashboard, the change is effected and shown on the Edit page but not on the published page(s). I also noticed that if the item is clicked, the changed currency is now shown. For example, if you open the above site, you’ll see a listing showing “First Test” with a price of $30,000,000. However, when you click on this item, the price is shown as N30,000,000 as intended. It should be made possible for the currency symbol to reflect the intended currency on first view. Hoping for a solution to this. Thanks.
You need to edit the icon in the plugin, because there is created a custom module please check the documentation https://forum.tagdiv.com/edit-modules-flex-block-x/
Thanks so much. I got it.
