Recent Post and Top Post Widgets
I have problems with recent post and top post widgets>
1. For top post widget It add home page link. I see that if you click visibility you can hide home and i check this option, but it don’t work.
2. For the recent post widget – I can’t add image thumbnails.
Thank you in advance.
dreamermagazine.com
1. That widget is not from our theme, please take a look about that widget if have an option to display only posts.
2. The recent post widget is default from WordPress and is styled to have only title post without image. IF you want with thumbnail you can use a block like you used for LATEST section, the results are the same.
Thank for your message!
