Recent Posts at top
I wanted to place ‘Recent Posts’ on top in my blog http://www.indianbeauty.tips. I wanted to keep recent posts just below the menu and wanted to place categories after the recent posts. Any suggestions?
Do you refer to the Recent Posts section that’s generated by the Homepage – with article list template? – http://screencast.com/t/bqYXfSe8j
You can remove it by switching to Homepage – blank template, for sidebar you can use the Widgetised Sidebar block – http://screencast.com/t/obAMqe83fv
Thank you, Emil G.
Hi Emil,
Thank you for your reply.I don’t want to remove the recent posts. I would like to place the articles in the below structure on my home page. Please suggest.
-Header, Menu
-Recent Posts with Pagination (page numbers-like the way it shows in my blog http://www.indianbeauty.tips home page now) with sidebar to the right
-After recent posts(or below the recent posts), I would like to the place tabbed widget (like the way it is in my blog http://www.indianbeauty.tips home page now) with sidebar to the right
Please let me know if you need more information.
Thank you
I have checked your site an noticed that you use the homepage - with articles list template so you need to edit the page-homepage-loop.php remove all the code inside the file and add this one: http://pastebin.com/gwXCMLre
You will get this result: http://screencast.com/t/qpigE6PmIDK
You can also set a sidebar just like before only that now the latest articles section will show up first on page and the page builder content after it.
Hope this helps!
Thank you Lucian for your reply. It works. But, only issue I see now is, numbered pagination is gone after I replacing the page-homepage-loop.php code provided by you. Can you please help me to put the numbered pagination under recent posts? Also, is it possible to put the numbered pagination for the page builder content too?
Thank you
Sorry about that I have made some modification to that file and sent you that way. Please use this code: http://pastebin.com/C1niWy9V
Unfortunately the numbered pagination can’t be used on block or page builder.
Sorry about this. Thanks for understanding!
Thank you Lucian. It works this time..
wrong message
