Recent posts do not appear on grid
I’m having trouble with the theme. He was using the Tech News model and everything worked perfect.
I switched to Gadgets model and I’m having problems with the order of the publications.
I configured Grid to show the latest news on Home, but it does not show. When I publish new news, it does not appear. It will only appear on the grid many hours later.
Can someone help me? It is as if the theme does not recognize the news immediately, only after several hours that it appears highlighted in the grid.
Hello Thalisson,
It seems to happen due to your caching plugin, sorry! Try to clear all of your caches and check the results.
Thanks for the reply, however I am not using plugin cache. Website: https://www.tudoemtecnologia.com
See that in the last news in the bottom of the site all appear, however in the highlighted grid do not appear! Only appear 1 day later. And that sucks, because I can not put news on the spotlight.
Thanks, I got it sorted out!
The problem was that I put the number 5 in the configuration of the grid. It was only to remove that it was perfect.
