Reduce padding "block 9" and "Popular categories block"
Is there any custom css I can use to reduce padding in these blocks so I reduce the height of the items?
I thing there is quite a lot of white space in these blocks.
I guess that you are referring to the line height Popular categories: http://screencast.com/t/G4iZnyfn
.td_block_popular_categories li{
line-height: 10px;
Also for block 9 please use this custom css: http://screencast.com/t/hwXcy6L1FRUQ
.td_block_9 .td_module_8 .item-details{
line-height: 20px;
margin-bottom: 0px;
padding-bottom: 0px;
Thanks a lot. Works perfectly!
Do you happen to know the .names to type in for “recent posts” and “categories” blocks available in the widget area?
Try this css if you want to remove margin and padding like above: http://screencast.com/t/7BFWK1sxYeCt
.widget_recent_entries li{
margin-bottom: 0px;
.widget_categories li{
line-height: 20px;
Thanks. Very helpful
