Reduce space around Header and page frame size while using boxed layout?
Hi, congratulations on a wonderful theme. I am using boxed layout with background ad and it works well. The frame around the header and edges of the page takes up too much space as shown in the linked picture.
Web Frame Spaces Too Large
Is it possible to reduce the frame to a bare minimum – can´t find the settings so please advise.
Best regards,
Editor at http://www.topp5.is
I could give you a code to remove the top padding below the main menu, and some of the container width, but this is highly not recommended. The theme width is predefined with or without background. This is meant to ensure that the page elements always display as intended.
The code you can experiment with would be like this
– https://www.screencast.com/t/n23fT520z
– https://www.screencast.com/t/fkHjIsJdq
.home .td-main-page-wrap {
padding-top:24px;
.td-boxed-layout .td-container-wrap {
width: 1116px;
.home .td-main-content-wrap {
padding-bottom: 24px;
Enter it in Theme panel->Custom Code->Advanced CSS in the desktop section, and check if everything works and displays properly.
Hi, it worked like a charm. Thank you very much for your help.
Best,
Agust
