Reduce space between top menu and header.
Hi there. Could you please provide some custom css that would reduce the space between my top menu and header. As you can see from my site: http://www.empiricalfitness.com the space above the header ad to the top menu is more than the space below the header ad to the main navigation menu.
I would like the same amount of spacing above and below the header ad to the menus.
Thanks in advance
Jin
Hi JFoulger,
Please try the code below and place it in Custom Css area: http://screencast.com/t/eWmnyaf1
.td-header-style-1 .td-header-sp-recs {
margin-top: 12px;
.td-header-style-1 .td-header-sp-logo {
margin-top:15px!important;
The result you should see here: http://screencast.com/t/pOREfvaUlGe
That’s exactly what I was after and it worked perfectly. Thanks! Always nice to know have excellent support for those of us that have limited/no coding knowledge 🙂
Hi JFoulger,
Thank you! Glad that i could helped!
