Reduce spacing between thumbnail and title, meta-info
I was able to resize the thumbnail size for block 21 as shown here: http://scotomastudio.com/issue-briefs-2/
I want to reduce the spacing between the thumbnail and title/meta-information as depicted in the image that I’ve attached. Reduce spacing depicted by yellow
You can use this code in the theme panel-> custom css box:
.td_module_16 .item-details{
margin-left: 160px!important;
It didn’t work!
It seems you have to reduce it again to about 110% : https://www.screencast.com/t/p8lZl3mx If you keep chanign the thumb sizes, the text will not move along with the image. If you adjust the images again, you have to adjust the margins again.
