The great thing about V6 you don’t need any CSS to take out white space it can all be done with the VC,each block you can fix all of that with out using any css…
take a look at my site and see what i mean https://jahliveradio.com
This is the default css for block 9 – http://screencast.com/t/Bz4eeEEC The padding and margin is added on module 8 so you can target block 9 to reduce the space(if this is what you want to do) – http://screencast.com/t/cEovuLLPlP07
.td_block_9 .td_module_8 {
padding-bottom: 10px;
margin-bottom: 10px;
